Need a list of Fluids and Filters
Just bought a Toyota 42-3FG15, serial number 42-3FG15-60034.
I would like to have a list of filters, fluids, and frequently changed parts, such as spark plugs, points, ect.
Any help will be appreciated.
Thanks
i_r_machinist
Some of what I have found
TOYOTA 42-3FGC15 Filter Removal & Replacement
a) Replaced engine oil filter w/ WIX 51034. (removed Toyota engine oil filter #32670-12620-71)
b) Replaced hydraulic filter w/ Fram C7553.
c) Replaced air filter w/ WIX 46070.
d) Replaced propane filter & gasket. (on Impco Vacuum Lockoff valve #VFF30.)
e) Replace Torque Converter filter w/ same Toyota Denso #32670-12620-71.
  • Posted 1 May 2017 02:19
  • Modified 2 May 2017 01:15 by poster
  • By i_r_machinist
  • joined 1 May'17 - 5 messages
Just obtained a Toyota Parts Manual for your machine. Posted on Google Drive, link can be found in my signature.
  • Posted 3 Jun 2017 03:01
  • By Jetty
  • joined 12 Mar'17 - 44 messages
www.BacliffRV.com/Toyota_Forklift
I just spent $100 on a manual that I hope will have our machines in it. I'll let you know what I find. I'm up in Dublin.
i_r_
  • Posted 4 May 2017 03:15
  • By i_r_machinist
Hello there,
I have the very same machine which I use at my shop in Bacliff, TX. Please find a depository of info for your forklift at:
www. bacliffrv.com/Toyota_Forklift
Regarding the ATF fluid, the "mechanic" I bought mine from suggested I use Dexron ATF. Not sure if that is totally correct...
Should you come across any further information please let me know and I will post it up there as well. Many thanks!
  • Posted 4 May 2017 01:29
  • Modified 4 May 2017 01:35 by poster
  • By Jetty
The transmission:
Asco
model: 32100-10520-71
serial: 3K0190
Aisin Seiki Co. Ltd
The dealer said to use Mobil ATF
  • Posted 2 May 2017 22:18
  • Modified 2 May 2017 22:19 by poster
  • By i_r_machinist
SMV (Konecranes) SL37-1200A
Morooka MFD20
