Travel Speed Adjustment
Hello all,
I've been trying to get the answer to this all day but to no avail.
I'm trying to adjust the speed of our Toyota Reach Truck 6BRU18
How do I adjust the speed?
Please respond to this forum or contact me
patrick(dot)heding(at)ingeteam(dot)com
  • Posted 26 Apr 2017 06:54
  • By patrick_h
  • joined 10 Mar'17 - 5 messages
  • Wisconsin, United States
Very helpful.
Just received a new-to-us Toyota 9BRU18. Found this older thread. About to crack into it following your instructions. Anticipating programs and wondering if there are any default passwords used when attempting this? If I find additional info, I'll happily contribute.
  • Posted 29 Aug 2024 09:07
  • By Vince13
  • joined 29 Aug'24 - 1 message
  • Virginia, United States
I suspected that but wasn't sure. Thank you for confirming. And again, i appreciate the help and all the replies :)
  • Posted 15 Sep 2023 19:46
  • Modified 15 Sep 2023 20:03 by poster
  • By Richard_Alameda
  • joined 30 Aug'23 - 4 messages
Safety is no accident.
I do not believe speed control came about until the 5 series trucks. They may have had some power control features but not speed limiting.
  • Posted 13 Sep 2023 04:31
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
@ErichO Hello again. Are you by chance familiar with the older Toyota model 2FBCA25? It's an older 2 ton electric forklift. However, it doesn't have the power select /hour glass /arrows panel. Perhaps those panels /display were manufactured after?
My facility just received one as a gift and am curious if this older model also has an adjustable speed setting. Any help in the right direction is appreciated. Hope all is well.
  • Posted 9 Sep 2023 16:27
  • Modified 9 Sep 2023 20:06 by poster
Thank you so much for helping me out brother! It's working on my Toyota model forklift!!
  • Posted 1 Sep 2023 15:25
  • Modified 9 Sep 2023 16:16 by poster
Primary password then secondary password. C5 for speed limiter.
Hr meter and Power control together...Beep, then up arrow..beep, then down..beep, then up/down together..beep
Secondary:
hr meter..beep, then hr meter and power control together..beep.
C5 1 through 8
Be sure to wait for beeps
  • Posted 1 Sep 2023 02:25
  • By ErichO
I know this forum thread is a bit old, but i have an important question too. How do i get to the tuning mode in a Toyota model number 5fbcu25 forklift? It's an electric 2 ton unit. To slow it down?? Any advice is appreciated.
  • Posted 30 Aug 2023 20:42
I need to adjust the reach speed on my 6BRU18 ser. 30997. the forks move out very slow. can anyone help
  • Posted 27 Mar 2018 10:00
  • By JoeMar
  • joined 18 Oct'16 - 14 messages
You rock!!!
  • Posted 1 Jun 2017 01:12
  • By patrick_h
hi. you have to go into tuning mode:
Tuning mode is used to change settings. Both
primary and secondary passwords are required
to enter Tuning mode.
Entering the Secondary Password
Enter the primary password.
Within 10 seconds, press the hour meter
select switch (system should respond with a
short beep).
select switch and the power control select
switch simultaneously (system should
respond with a short beep).
'Tuning" will appear on the display indicating
acceptance of the secondary password.
then you have to select the tuning code "C4" for maximum speed limiter: The factory default will show as the highest setting (1-8)
segments on. Moving down from the "8" will change the
maximum travel speed by 0.5 mph per character.
let me know if this helps.
  • Posted 18 May 2017 07:53
  • By CarlosCol
  • joined 13 May'16 - 28 messages
  • Bogota, Colombia
Sue Tomic Sue Tomic
