Thermal protector issue code -41
I am working on bendi where at first I was having a code 24 fault saying the voltage at T2 is too high. Change the card and now I am getting a code -41. Check the thermal sensor it is working, done all other checks and it won't allow me to drive the truck. I change REC 1. Any help would be greatly appreciated
  • Posted 19 May 2023 11:19
  • By chris
  • joined 19 May'23 - 11 messages
  • Jamaica
Cfolkes
Showing items 1 - 19 of 19 results.
hey scott_, updating on the Ev100 issue I am having. I went ahead and reinstall the original card and I am still seeing the code 24. I also observe another bendi forklift same EV100 and I realize there is a contactor that would close then open with the fwd./rev contactor but on the truck I am working on it isn't happening. I change out the contactor thinking its the coil but same problem.
  • Posted 7 Jun 2023 05:41
  • By chris
  • Jamaica
Cfolkes
Thanks. Yes beautiful country. As for the height error. It not showing it anymore. Just drive speed issues in either direction at times. I have noticed anytime it is driven over ruff surfaces and get heavy jerks it move slow in speed. Thanks a lot for your assistance, was really an eye opener
  • Posted 22 May 2023 11:22
  • By chris
  • Jamaica
Cfolkes
I usually work on a lot of older machines some electric and some lpg that's good that you programed the truck l have worked on some orderpickers with curis controller the ones l worked on with height problems usually was bad height encoders they would not count as the platform was lifting or had bad 24inch proxswitches that would make the truck drive slow there is a company near me that repairs most controller and sells rebuilt or new they are factory cutis repair site.As far as Jamaica me and my wife have gone to montego bay approx 14 times we stay at sandlers royal or montego bay we haven gone in in a long while was there in 2001 last time. It is beautiful there.
  • Posted 22 May 2023 11:13
  • By Scott_
Well for me I have just 4 years under my belt but do come a far way. I am in Jamaica where I work on the electrical forklift from EV 100 to the later ones with modules and controls. I have a hyster stockpicker working on now with the Curtis controller. I was having a heighter error code on it, after diagnosing it was the controller defective. We bought a blank controller and manually programmed it ourselves but afterwards we found the truck speed decreased to creep speed in going fwd and normal speed going reverse also it interchange with the direction.
  • Posted 22 May 2023 10:21
  • By chris
  • Jamaica
Cfolkes
Yes this system was in older trucks today a lot of young guys don't know much about the EV 100 and even older EV1 l am still turning wrenches but been working on lift trucks for 39years have a few more to go till l hang it up
  • Posted 22 May 2023 09:45
  • By Scott_
Scott
Appreciate the discussion we had. Question, are familiar with the Crown and hyster stockpicker?
  • Posted 22 May 2023 07:14
  • By chris
  • Jamaica
Cfolkes
Ok let me know how you make out best of luck
  • Posted 22 May 2023 07:07
  • By Scott_
Scott
I will swap back the original card back in wher I was getting the code 24 and see if there is any difference. I have one option leave in which I would change the REC 3. The pigtail type diode because that code is saying the voltage is too high at T2
  • Posted 22 May 2023 06:29
  • By chris
  • Jamaica
Cfolkes
I think you stumped me on this one l don't understand if you have positive and a negative at the contactors they should pull in when you put the directional shifter in forward or reverse and if it drives l would say that the components are good.l run out of options if l think of something l will get back to you and if you fix it let me know
  • Posted 22 May 2023 06:21
  • By Scott_
Scott
That's what I was wondering if it is the PB plug in was my issue. I did checks on it but getting good reading on wires going to the coils. That's why I swap the card from another truck and try but having a different issue
  • Posted 22 May 2023 01:14
  • By chris
  • Jamaica
Cfolkes
Sorry l did not get back to you last night but l just read your last post look like your on the right track check the PB plug on the card that is the pmts output to the coils l believe #4#5wire is forward and reverse l think #1is FW,and #2RB
  • Posted 22 May 2023 00:50
  • By Scott_
Scott
I think it is a pmt issue. The capacitor charge. Change rec #2 & 5 recently. What I realized though if I manually engage the contactors you can get the truck to move in either direction. You know there are fwd and reverse contactors that work with RB and Fw. When you put the truck in either direction only one of those contactor close. So the fwd close but not RB or the Reverse close but not FW.
  • Posted 21 May 2023 09:35
  • By chris
  • Jamaica
Cfolkes
Chris am not sure what the problem is let me ask you l guess no contactors come in now but when you go in forward or reverse is there any SER hum and have you seen if the capacitor. is charger after you shut the key down if not it may have a bad #2rec the rec comes in first before the #1rec to charge the capacitor.do you have any way to check to see if it gates. if you can not find the problem there is a couple places that you could pull the complete panel and send it to them l not sure we're you are located.
  • Posted 21 May 2023 09:01
  • By Scott_
Scott
Yes all inputs are okay. The pmt on this truck is a part of the card. T2 on REC1 would be where the negative side , voltage coming to the REC would be 48volts but on the other side am not getting that
  • Posted 21 May 2023 05:18
  • By chris
  • Jamaica
Cfolkes
Does sound strange the thing that does not make sense is why it would drive in reverse and not forward anything as far as components on the board that failed would not drive in any direction did you check at the tb screws 1to 6to make sure that all inputs were there also does this card have built in pmts or are they on the outside on the board if they are on the outside it is possible that the forward is going bad as far as the 3and 5rec it would not drive in any direction don't think that is it
  • Posted 21 May 2023 04:37
  • By Scott_
Scott
I got a new battery and it was the same issue. It is very crazy and weird. I literally did all the troubleshooting possible cause of the problem. I have been thinking if it is REC 3 or 4. Or it is a neutral problem.
  • Posted 21 May 2023 01:44
  • By chris
  • Jamaica
Cfolkes
Chris this sound crazy but have you checked the battery for a shorted cell l say that because when you lift that is what takes more amps than drive if the battery was weak it would shut down the truck and low voltage plays games with controller
  • Posted 21 May 2023 01:18
  • By Scott_
Scott
Thanks for your reply. For the first code which is 24. I have change motors and fwd, Rev contactor. I changed the Main SCR controller, changed subbers. When the truck start it move in reverse and then when try going fwd it code out. What I notice when I try lift functions it shut down the truck completely. So when I change the card I start to have a thermal issue as I try to accelerate the truck. I change the thermal sensor and the REC1 but still having the same issue. I have no handheld.
  • Posted 20 May 2023 13:01
  • By chris
  • Jamaica
Cfolkes
First l have not worked on bendi lift trucks much but it sounds like this truck is using a GE EV 100 system in it by the codes you are getting if so what would have made you replace the control card the first code is talking about the forward and reverse contactor l would have looked to make sure that the contractor is going back to the open position and both are touching the tips look for a stuck tip or welded check the coils for the correct ohm reading do you have the old card if so put it back and see it code 24 comes back some times with the new card you need to take out all the parameters and install in new card but l do not think this is a card problem make sure when you installed the 1,rec the thermo protector was installed on the rec and the wires did not break get back to me after you look at that and l will try to help you do you have a hand set?
  • Posted 20 May 2023 09:18
  • By Scott_
Scott
Maxlion FD30
Enforcer FD50T-MMA
Hawker Powersource, Inc.
Maxlion FD30
Enforcer FD50T-MMA
