Technical / Maintenance & Operating manual BOSS LE16-100 MKVA1
does anyone have this info so that we can understand the startup error codes and repair the steering servo. Serial nr = 207481.
Thank you in advance !
  • Posted 2 Nov 2012 23:59
  • By SOLIVI
  • joined 2 Nov'12 - 9 messages
  • Antwerpen, Belgium
Showing items 1 - 16 of 16 results.
Hi, if you can help me, I am working on forklift Boss LE18HV and have following error code AR04. Thank you in advance!
Dragan
  • Posted 14 Dec 2019 07:43
  • By dragan_p
  • joined 14 Dec'18 - 28 messages
  • Bosnia And Herzegovina
mbprolic hotmail com
If its fitted with a LT 200 controller it could be 1 of 3 issues
1: Remove drive card and clean the two shunt wires connected to the bus bar and resolder internally to the board.Make sure you dont fit them back the wrong wayon ther bus bar when rebuilding.
2: Controller may need reprogramming but to do this you need a LT200 box
3: Faulty controller so you need to send it away for repair.
  • Posted 2 Jun 2019 01:13
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
Hi there. I am having trouble with a boss Le16. Hyd and power steering work OK. Put into drive and contacts come in but wheels will drive if off floor. On the ground it's as if no power to drive wheels. Does anyone have a manual or error codes for these.
  • Posted 1 Jun 2019 19:46
  • By Zulu
  • joined 27 Feb'17 - 6 messages
  • South Yorkshire, United Kingdom
Hi, I know its a long shot as this is an old thread but, I have some error codes on my LE16, is there any chance I could have a copy of the error codes please.
Email address (without spaces etc): sales @ abwelding dot co dot uk
Thanks in advance to anyone that can help, Andy
  • Posted 19 Sep 2013 18:40
  • By Aoraki
  • joined 19 Sep'13 - 1 message
  • Notts, United Kingdom
thank you for the input, we'll check this out and let you know. The contactor is indeed clicking (we can also see the lever moving on the relay).
Initially the problem came in sporadicly 3 or 4 times, and then suddenly it didn't resolve anymore. Your suggestion to look for the brushes will be checked.
  • Posted 8 Nov 2012 00:04
  • By SOLIVI
Normal problems with power steer on these is either, pressure switch on oribitol valve, contactor or most common is power steer motor brushes.
If your contactor is clicking when you try and steer I will pretty much guarantee its the motor. Sometimes giving it a tap will make it go temporally.
  • Posted 7 Nov 2012 23:36
  • By danny_k
Glad i could help
  • Posted 7 Nov 2012 05:16
  • By powerlifter
remove the spaces (this blog refused to take email addresses and/or urls) [email address removed] lets try again.
  • Posted 5 Nov 2012 18:17
  • By SOLIVI
remove the spaces (this blog refuses to take email addresses and/or urls) [email address removed] so the prefix = info, then the at-sign, then our domain name "solivi" and the suffix is ".be"
  • Posted 5 Nov 2012 18:16
  • By SOLIVI
Sorry but that email is invalid, do you have a full email address???
  • Posted 5 Nov 2012 04:05
  • By powerlifter
info @ solivi. be
  • Posted 5 Nov 2012 02:00
  • Modified 5 Nov 2012 02:01 by poster
  • By SOLIVI
Do you have an email address?
  • Posted 4 Nov 2012 23:46
  • By powerlifter
at startup several codes are displayed (repeating itself) for 10-20 seconds : 005 226 002 003 (cannot read inbetween because too rapid) 008 009 008 009 008 009 008 009 and when it stabilises it shows 70 from the battery level.
after a few moments one can operate everything except the servo steering
  • Posted 4 Nov 2012 22:53
  • By SOLIVI
The machine is fitted with a LT200 controller what codes are you getting ??
  • Posted 4 Nov 2012 03:05
  • By powerlifter
A good engineer is a helpful engineer
it is a series of codes at startup, and after a few moments it just displays the battery capacity. It is not always the same, but I need to capture it at our warehouse.
The problem we have is that the servo steering doesn't work anymore and steering is very very heavy. Priority is to solve that one and I need the hydraulic and electric schematics + physical exploded drawings to start looking for the problem.
  • Posted 3 Nov 2012 19:06
  • By SOLIVI
It could be the same as Jungheinrich EFG DF16. What error code number do you have?
  • Posted 3 Nov 2012 18:08
  • By phi_g
  • joined 3 Nov'12 - 6 messages
  • Harjumaa, Estonia
Toyota 8FD45
Hoist Liftruck F180-36BOX-CAR
