T50D CAT HYD. not holding
Lift@tilt slowly leaks down,and forward.No externel leaking.I dont believe t50d has packing in lower end of lift cylinders?Thanks for any help.
  • Posted 30 Jul 2012 00:10
  • By kent_w
  • joined 5 Jan'12 - 102 messages
kent,
try checking the control valve
the following problems can cause this symptom
- valve spool springs are weak or broken
- internal control valve leakage (worn spools)
- load check valves defective
- leakage of cylinder lines or piston seals
- trash in the control valve
one of these things could be causing your leak down of the lift and tilt
pull the valve and check the neutral return springs and make sure they are not broken, generally if this is the case the lever will be very mushy and will not have that 'neutral detent' centering when you let go of it. Also remove the check valves and relief valve and make sure there are no broken springs in those. check for any debris while checking these.
If you find no issues from the above checks then you may have a cylinder packing problem causing leakdown.
good luck
  • Posted 30 Jul 2012 01:49
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Muncie, IN, United States
Crown RD572513TT6860R
Taylor TX330S
USD159,500
