suddon surge of speed
The driver of this truck reported that when he was driving all of a suddon the truck just sped up and he couldnt control the speed. It was like the truck went full speed or nothing? But when I came to check the truck over the next day, the problem was gone and the speed control was fine? Any ideas
Hunslet Lizard model 1508-45 serial number RTNO-562 not sure on year of manufacture
  • Posted 18 Jul 2013 00:22
  • By suchy1977
  • joined 5 May'13 - 22 messages
  • humberside, United Kingdom
Edward
I wasn't refering to the bad spot as being an "open circuit". I was leaning more toward it being a "hotspot", causing the voltage to jump to full range instead.
Maybe I should have clarified that instead of just throwing out that rather broad suggestion. :o)
Sorry about that
  • Posted 18 Jul 2013 22:51
what type of controller is fitted? very few controllers will have high speed as the 'open circuit failure' of the pedal position pot.
I think it is more likely the linkage to the pot slips, I have seen some that have a piece of hose to connect the pot shaft to the linkage, and the hose slip, but even that will eventually show a code in an ev100 (or newer) system.
  • Posted 18 Jul 2013 20:15
Faulty accelerator?
A bad spot in the pot wiper may cause a sudden change in the signal to the controller causing it to go into full speed.
  • Posted 18 Jul 2013 03:24
Hawker Powersource, Inc.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
October 12-15, 2026 - Detroit, MI, United States
