Stuck in Forward.
Hello all. I have a Skyjack SJIII 3226. It is stuck in forward. Push the joystick will go forward. Pull the joystick it still goes forward. Will raise and lower no problem. Did some research and it could be a faulty valve? I am pretty mechanically inclined so i think I can tackle it myself just need to know where to start. Thanks in advance!
  • Posted 2 Apr 2024 05:40
  • By Al_H
  • joined 2 Apr'24 - 1 message
  • Alberta, Canada
Find the Vickers valve assys mounted to the side of manifold...start by disconnecting the forward coil...if when you activate reverse..the machine drives forward...swap the 2 vicker valve assy's...should then drive forward and reverse but constantly turn on one direction...get a new bicker valve assy...if not when you disconnect the coil if it stopped, then diode probably bad going to wire number 16 for forward
  • Posted 12 Apr 2024 14:16
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
UN Forklift FBRP15NQZ2
Terberg RT403
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
Terberg RT403
