stops runnimg
a friend of mine has a lift that stops running after 15 seconds restarts and dies after 15 seconds any tips thank you. Don Watson.
  • Posted 9 Feb 2010 13:45
  • By hornet
  • joined 9 Feb'10 - 1 message
nothing works
would be a big help to know make, model and serial numbers, this sounds to me like the LPG lockoff is not getting power in the "run" position of the igntion switch, but the reason for that depend (like Barfly Olaf says) on "emmission compliant or standard" as to where the power should be coming from. I would check the relays if it's a "CARB" truck
  • Posted 9 Feb 2010 23:39
Is it emmission compliant or standard? Could be many things. Check oil pressure light and sensor
  • Posted 9 Feb 2010 21:03
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
SEMPER FIDELIS
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
