Still RX 50
Hi
This truck will not start up after keyswitch on , if i pull the fuse 15A on the top of the black controlbox on the rear left side many times out and in the contactor comes in and everything works oke. If i set keyswitch out the display goes off and couple of time later i set the keyswitch on ,the same problem.
I think a capicitor fault in the box?
On the right side on the rear i have a grey box.
Truck give not a fault for this problem
  • Posted 16 Jul 2012 23:51
  • Modified 17 Jul 2012 14:57 by poster
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi All , i check the battery back in the display , they are defect i replace it for new and truck starts up. Thanks for the info..
Regards
  • Posted 19 Jul 2012 19:36
  • By gc_d
Regards gc_d
Yes i had same problem and it was the little flat battery in the back of the display.
  • Posted 18 Jul 2012 01:59
  • By elektrodrive
enquiries@elektrodrive.co.uk
No friend, is not located in the rear side, I'm refering to "display console" in right front side of the truck.
Regards
  • Posted 17 Jul 2012 18:44
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hi , Sorry ,on the left side rear the black box and right side rear the grey box , i will check the battery
  • Posted 17 Jul 2012 14:58
  • By gc_d
Regards gc_d
Remove console and check the button battery inside it. back in the console has a small cap to remove this button battery.
The voltage reading of this battery should be 3v, if lower reading replace the battery
battery STILL REF. 526618
Regards
  • Posted 17 Jul 2012 05:10
  • By nacsand_n
  • Madrid, Spain
Hello
You think good because something get discharged and you have problem to start up. you must to check voltages and to see are they good if not problem is outside in wiring or contact if is everything is ok with voltages problem is in control box.
One more thing check that line to contactor maybe you have there problem in coil or contact how i know signal for contactor come from control unit.Good luck
  • Posted 17 Jul 2012 02:18
  • By nemanja_k
  • serbia, Serbia
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TX330S
USD159,500
Deborah Baker Deborah Baker
Muncie, IN, United States
