STILL R70 electric drawings
I am restoring a STILL R70 forklift (1988). It has serious electric problems both the control circuit boards are suspect. Does anyone have the details on the boards?
Please help me out.
Thanks
Jerry
  • Posted 20 Jun 2006 05:35
  • By jerry_p
  • joined 29 May'06 - 4 messages
  • Netherlands, Netherlands
Showing items 1 - 20 of 36 results.
i have the same problem with a diesel truck
https://hellodear.in
https://teatv.ltd/get-apk/
  • Posted 21 Apr 2023 00:15
  • By axedztop
  • joined 18 Apr'23 - 2 messages
  • American Samoa
I have the same issue with our truck. Could you send me the wiring diagram as well. That would really help me out!
  • Posted 18 Apr 2023 20:12
  • By axedztop
  • American Samoa
Hi boys ,r70-25 mercedes engine , drive pcb nobody has news?
contact i will pay
myamev8 at hotmail. com (no spaces)
  • Posted 8 Apr 2023 00:38
  • Modified 8 Apr 2023 00:44 by poster
  • By ame_belve
  • joined 7 Apr'23 - 2 messages
  • Italy
Beautiful day!
I would like to ask big help!
I took it as myself one 1990 es Still R70-30T trolley. How that mistake of his is not going unfortunately neither ahead back. I would like to ask a drawing from him, if solvable. Dared unfortunately do not find nowhere.
I would be very grateful if you would be able to send it!
Ahead thank you very much!
With respect Csaba
[email address removed]
  • Posted 18 Apr 2022 02:14
  • By Bistey_Csaba
  • joined 18 Apr'22 - 1 message
  • Hungary
Hi Manuel. Did you find electric schematic for power board I have similar problem. On electric drive motor exiter is always under power and draw more than 20amps power from battery. Nothing change when I remove key.
  • Posted 11 Jul 2021 23:49
  • By Damir_Damir
  • joined 20 Feb'21 - 1 message
  • Bosnia And Herzegovina
Hi Jerry,
  • Posted 17 Oct 2019 20:41
  • By Manuel
  • joined 22 Sep'19 - 10 messages
  • Netherlands
  • Posted 28 May 2019 16:21
  • By kris_r
  • joined 28 May'19 - 1 message
  • Belgium
Bump
Help please
  • Posted 9 Mar 2019 04:19
  • By stevan_v
  • joined 6 Mar'19 - 3 messages
  • Serbia
Helo,
I have a STILL R70, from 1988, with VW diesel.
I need the wiring diagrams, if any body can help.
The same problem with driving, the other things working.
Thanks in advance
  • Posted 6 Mar 2019 09:37
  • Modified 6 Mar 2019 09:47 by poster
  • By stevan_v
  • Serbia
Hi,
do you have Electric scheme for still R70? Pls send me.
Thank you
Jan
  • Posted 30 Sep 2017 01:32
  • By jan_f
  • joined 30 Sep'17 - 1 message
  • Czech Republic, Czech Republic
Hello.
We have Still R70-20 Mercedes Diesel Electric Truck 1988/9, We want to change the starter ring gear. Can anybody give us a procedure for removing the generator to get to the flywheel to replace ring gear.
  • Posted 6 Feb 2016 01:29
  • By Bathy21
  • joined 6 Feb'16 - 3 messages
  • Yorkshire, United Kingdom
Fix anything, help anyone always interested.
Hi, i have a still R70-16 triplex with a VW engine and is powered by LPG.
The engine runs, the forks work but the not drive. I have checked the fuse which is OK, handbrake switch is also OK, but I do not have any manual repair, so i need the wiring diagram and ideias!!
number 70371748
Thanks.
  • Posted 9 Oct 2015 07:14
  • By ajppires
  • joined 9 Oct'15 - 2 messages
  • santo tirso, Portugal
ajppires@sapo.pt
Hello,
Please send information for u200.
Thank you.
  • Posted 3 Feb 2015 09:56
  • By doru_l
  • joined 3 Jun'13 - 4 messages
  • Timis, Romania
Hello
can anyone to send me electric drawings for u200 and u36 board
Best regards
Nikola
  • Posted 7 Dec 2014 10:22
  • By nikola_m
  • joined 3 Dec'13 - 14 messages
  • ohrid, Macedonia, The Former Yugoslav Republic Of
Hi Jerry
Can you send me the drawings you do have.
Thanks
Greg
  • Posted 4 Dec 2014 22:59
  • By greg874
  • joined 3 Dec'14 - 3 messages
  • NA, Ireland
Hi Jerry
Thanks
Greg
  • Posted 4 Dec 2014 22:58
  • By greg874
  • NA, Ireland
Hi
I have a 1990 still r70-45 merc diesel forklift but no wiring diagrams can anyone help, as the truck will not move forward or back but does rev up as you step on the pedals
Thank you
Greg
  • Posted 3 Dec 2014 03:08
  • By greg874
  • NA, Ireland
fix me
Hi, I am also after a wiring diagram for a R70-16 with a VW engine and is powered by LPG.
The engine runs, the forks work but the truck will not drive. I have checked the fuse which is OK, when you hold the coil in it will then drive, so the fault is on this safety circuit which includes the handbrake switch, but I do not know what else is in this circuit, hence needing the wiring diagram.
Thanks.
  • Posted 27 Jun 2014 00:11
  • By Fatpieface
  • joined 27 Jun'14 - 1 message
  • Wales, United Kingdom
hello every body,i am new in this forum too.i have still R70-40(old diesel),the engine is ok but when we want to move it the BUV20 (power transistors) of the power board become damage.I would like to have a electric drawing or service manual, every body would you help?thanks.
  • Posted 29 Apr 2014 21:04
  • By memo_j
  • joined 29 Apr'14 - 1 message
  • alborz, Iran, Islamic Republic Of
Hello every body, I am new in this forum,and I have STILL R70 25 (gas),the engine starts normally,forks are ok, but no drive.
Please can any boby send me any wiring diagram or drawing.
Thanks all.
  • Posted 13 Nov 2012 05:31
  • By mokh
  • joined 13 Nov'12 - 1 message
  • batna, Algeria
Muncie, IN, United States
RAEDER-VOGEL
