Still R70-80 1999 drive forwards in neutral and reverse?
Hi , i have a crazy error in a Still R70, truck drive if you touch the accelerator pedal and can not stopping if you release the pedal ,after 10 seconds it stops it is very dangerous, i set the direction lever in neutral or reverse ,it drives forwards.. Dash light comes up if the lever in neutral. I check the wiring and connectors and lever switches but everything oke, Any idea were i can search or check?
  • Posted 21 Jul 2012 01:29
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
hi i have been told it is the control card front one just bought one off ebay hope it will fix it will let you know regards dave.
  • Posted 7 Dec 2012 05:21
  • By granitedave
  • joined 10 Jun'12 - 5 messages
  • south yorkshire, United Kingdom
Hi , no i have not fix it , i think the right controlcard on the front are defect but i am not sure. I hop you have an idea?
  • Posted 7 Dec 2012 05:14
  • By gc_d
Regards gc_d
hi i have the same problem with my still r70 diesel stuck in drive cannot get it out have you fixed the problem if so can you let me know regards dave?
  • Posted 30 Nov 2012 05:09
  • By granitedave
serialnumber is 517046001095
regards
  • Posted 23 Jul 2012 15:24
  • By gc_d
Regards gc_d
which is the truck serial number?
  • Posted 21 Jul 2012 23:40
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hi the conactor on the left side under floorplate comes in with engine on so ithink this is oke , i have check the four diode blocks by the contactor and check oke. You think the right module on the front of the machine ? powermodule 2a1 ?
  • Posted 21 Jul 2012 14:40
  • By gc_d
Regards gc_d
If wiring is OK, probably any transistor/transistors burned in power module. You should remove it to check. Do not open C26 contactor?
Regards
  • Posted 21 Jul 2012 03:23
  • By nacsand_n
  • Madrid, Spain
UN Forklift FD40T
SMV (Konecranes) 4632CC5
Muncie, IN, United States
Bolzoni SpA (Group HQ)
