Still R60-40
Hi all,
Have anyone info about a Still R60-40 for setting the parameters for drive.
I have two controlcards left in the back of the truck under a black plastic box.
I want to know how i can change the settings on the print
Serialnumber 60161784 1994 80 volt
  • Posted 16 Apr 2010 03:57
  • Modified 16 Apr 2010 04:00 by poster
  • Discussion started by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Dear All,
A STILL R60 45 shows on the screen HELLO and is immobilized.
Does this happened to any one and can help me find out what the problem is??
No Fauld codes only HELLO
I got same problem aceleration pedal works with high reaction. did you find the problem. Thanks
  • Posted 7 Dec 2022 03:19
  • Reply by prezes
  • Poland
Hello everyone ,
I got same problem as diego with R60 25 80v. ,acelerator pedal the truck has no reaction when if you push at the top it acelerates without regulation and goes max speed , was it solved ? and if yes please let me know
thanks in advance
  • Posted 8 Mar 2019 19:55
  • Modified 8 Mar 2019 21:21 by poster
  • Reply by dato_georgia
  • Georgia
Hi,
There is a problem with CSC (curve speed control). When the truck starts it will drive with maximum 5 km/h until one of the sensors is active.
Check the sensors from the steering axle.
You don't have to adjust the address 150. It is already set to value 1, that means you will see the errors on the dashboard.
Best regards
  • Posted 5 Apr 2018 21:17
  • Reply by Dejavu
  • Bucuresti, Romania
It may look like I'm doing nothing, but in my head I'm quite busy.
Dear mate
I also have Still R60-40 serial 516027000860, all of function are out of order, on the console we have error 36?
I check very carefully the seatswitch, safety microswitch on travel pedal, parking barke, brake sender and all working properly
I wanna to try with service address 150 to diagnose all the switch and potentiometer but do not know how to set 150 on the dashboard ( maximum I can reach the address is FE cause it has only 2 digits)
Please help me
  • Posted 13 Mar 2018 00:02
  • Reply by lsj_f
  • No, Indonesia
It sounds like an input problem from the throttle pedal or wiring. If there was a fault in the controller the machine should fail safe when it goes into full speed. Check the throttle pot and all the wiring to it, you should not need to adjust any parameters.
  • Posted 18 May 2010 15:24
  • Reply by AndyPandy
Hi AndyPandy, first my respect to you and thanks for your time.
I have a Still R60-25 (1998) with a problem of traction. When you push the acelerator pedal the truck has no reaction but if you push at the top it acelerates without regulation. May i have a problem with any of the parameters?, in wich case, how can i modificate them?
Thanks.
  • Posted 15 May 2010 08:54
  • Reply by diego_c
  • Buenos Aires, Argentina
The drive card is the top one nearest the front og the truck and the pots are as follows.
From the left as look into the truck from the rear.
GB=travel speed limitation
HZ=rate of acceleration
BS=regen current braking
FS=Current limit
RS=Plug braking current
Anti clockwise to increase and clockwise to decrease.
The pump card adjustments againn starting from the left are as follows.
4=4th service speed
3=3rd service speed
2=Tilt speed
1=Lift speed
SK=Hydraulic start speed adjustment. Turen this pot clockwise until the pump motor starts, then turn anti clockwise until it stops, then turn 1 more turn in that direction.
Hope this helps.
  • Posted 19 Apr 2010 19:50
Hi Andypandy,
Yes that is right. I have seen the pots on the top of the controlcard but i have no info witch one for traction or reversebrake etc. So i can not change the settings....
Regards
  • Posted 17 Apr 2010 03:47
  • Reply by gc_d
Regards gc_d
I will have to dig out the information on this, can you confirm that this is an older SCR type control unit and exactly what you wish to change. If this is one of the older SCR units one card is for the drive and one is for the hydraulics. These are adjustable on the pots facing the top of the card, but there are limits to what can be done.
  • Posted 17 Apr 2010 01:43
ROYPOW
edition #1234 - 12 June 2025
JLG 450AJ
JLG 450AJ 2017
Flesherton, Ontario, Canada
Airman ENCL045
Hyster
Your Focus
