Hi Clinton,
pls let me know your truck serial number, you should have an id plate on your truck. if the id plate is missing check the chassis for a stamped number - can be located either in the area of the front wheel arches or under the overhead guard on the rh side.
Brad
Thanks for your help Brad.
Since i never worked on one of these can you please tell me where to find the current sensor. If you have circuit diagrams can you please send them by e mail on clintoncutajar @ yahoo.com. Thanks again
Hi Clinton,
it sounds like you have a problem with your current sensor, does the problem occur when you change direction from forwards to backwards or from backwards to forwards - if the answer is both then check the current sensor!
Brad
