Hi peter,
What should be the resistance of a good temp sensor? I have code 198 on a still r60-20.
Is this fault to pump motor or drive motor?
If you have more information, you can send me if you like.
Hy aswin , look with atention at the traction motor. look at the carbon brushes to slide free in the case.
somethimes when the carbon brushes is stuck, is this problem..
Hello, I have also a problem with my forklift, it is sttill 70-25 i, and it show on the monitor error 225 and error 197 and do not whant to work forward and reverse.
Check fuses on the pcb next to the controller in the ballast weight, I think it is F3 that supplies power to the brushes/temp sensors. Also check the resistance of the temp sensors.
Pete
