Still error FE23
Hi
Customer said truck was driving fine but no hydraulics
Replaced all 3 phase motor cables (correctly) as insulation was poor/hot/burnt, 1 terminal failed. Hydraulics now work but traction does not. Any pointers? I question the insulation on the motor terminals where it passes through the motor body but dont really want to delve too deep just to check on a hunch, disconnecting motor cables changes the error to fe42. Any ideas guys?
  • Posted 1 Sep 2016 01:21
  • By andy_j
  • joined 16 Aug'12 - 38 messages
  • Uk, United Kingdom
Tienes el listado de errores general?
Tengo error Fe 06, 05 y 23.
No eh logrado encontrarlo. Gracias
Please use English language
Littoral translation
Do you have the general error list?
I have error Fe 06, 05 and 23.
I haven't been able to find it. Thank you
  • Posted 27 Dec 2023 21:22
  • By luis_silveira
  • joined 27 Dec'23 - 2 messages
  • Uruguay
Fkluis
Hello.I am having problems with the electric forklift. car fm-14x it shows error FE0100 Fe2020 Fe2181... i don't know what that error code is. Please guide me
  • Posted 4 Apr 2021 02:08
  • By mr_l
  • joined 18 Jun'18 - 4 messages
  • 180000, Viet Nam
Soidaudan86
FE23, Travel converter internal fault
The internal safety circuit in the converter has detected a fault. The output power is
switched off.
The converter must be replaced.
FE42, CAN bus 2 communication error between FPS and travel
converter
The FPS is not receiving any data from the travel converter. The main contactor K1 is
opened.
Check that the CAN bus 2 wiring and bus terminal are correct (see "CAN bus, Bus
structure CAN 2").
If the CAN bus is OK, the converter must be replaced. To test whether the converter is the
problem in faulty bus communication, the component can be contacted directly via the
onboard diagnosis of the display (Software version query, see "Display, Onboard
diagnosis, Software version query"). If Version 0.00 appears on the display when the
query is made (see "Display, Onboard diagnosis, Error codes") the component is faulty.
Remark: (Converter to 04/2005). This error message is also issued if the 48V supply
voltage is missing at X1.1 of the converter (see "Converter, Status LED"). This
is, for example, the case when the emergency-stop button has been actuated.
This error can also be caused by an incorrect converter encoding (cf. "Converter,
converter encoding").
Remark: (Converter from 05/2005) If the 24 V supply voltage is missing at X1.15 of the
converter, this error message also appears. Also if the connection FPS X1.12 --
travel converter X1.11 is interrupted when switching on the truck (cf. "Converter,
supply and enabling (from 05/2005)")
  • Posted 15 Jan 2017 08:54
  • By tomason2
  • joined 5 Apr'15 - 53 messages
  • Poland
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
Hawker Powersource, Inc.
Mohammed Kabir Mohammed Kabir
Chief executive officer, Corvus Robotics
Regional sales manager, Abbey Attachments
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
