Steering problem
Hi. I have 7fbe20 steering is not working at all and no error is shown. What could be the problem
Seems like no current is going to the steering pump but even when I press the hydraulic function steering also lot works
All functions are working move front rear hydraulic ect
  • Posted 3 Dec 2022 20:35
  • By marantonious
  • joined 19 Jun'18 - 48 messages
  • kuwait, Kuwait
Marc ANTONIOUS
Right has one hydraulic pump
And one steering Valve
  • Posted 12 Dec 2022 20:27
  • By marantonious
  • kuwait, Kuwait
Marc ANTONIOUS
You cannot be working on a three wheeled 7 FBE 20? Surely your working on a 4 wheeled 7 series?
  • Posted 12 Dec 2022 19:02
  • By Forking_Around
  • joined 17 Jun'21 - 43 messages
  • New Zealand
It's the same pump, it only has one hydraulic pump.
  • Posted 12 Dec 2022 18:59
  • By Forking_Around
  • New Zealand
It was steering pump. Not hydraulic main pump
Normal all function was ok except the steering
  • Posted 12 Dec 2022 18:12
  • By marantonious
  • kuwait, Kuwait
Marc ANTONIOUS
That's odd? Pump doesn't generate power it simply creates a flow, it's the resistance to that flow that creates the pressure and if it created enough flow to operate your lift/tilt/side shift then you'd have to say your pump is fine.
  • Posted 12 Dec 2022 17:05
  • By Forking_Around
  • New Zealand
Thank app of you for the support
The pb is the pump itself
Couldn't generate the enough power
I replaced with new and working perfectly now
  • Posted 12 Dec 2022 16:50
  • By marantonious
  • kuwait, Kuwait
Marc ANTONIOUS
Sorry for that, i was mistaken with the 7FB18, 4wheel.
  • Posted 11 Dec 2022 21:59
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Surely the 7FBE is AC motor and not DC? Faulty steer sensor, bottom left hand side on steering orbitrol unit.
  • Posted 11 Dec 2022 19:38
  • By Forking_Around
  • New Zealand
Mostly the pumpmotor is the problem, check for insulation resistence and brushes, there can be a lot of brushdust inside.
If you are shure the pompmotor is oke then check the PS Controller, situated left side next to battery.
The Transistor will be broken, and DC/SD board will be broken to.
  • Posted 6 Dec 2022 08:20
  • By John50
  • Netherlands
Tusk 500PGH14
Taylor TX330S
USD159,500
Tusk 500PGH14
Taylor TX330S
USD159,500
Michel Denis Michel Denis
