Linde (& Baker) B-30 TES:
Steering and hydraulic lift
I have a problem with steering and lift when key is turned on steer motor starts and shuts off. It will only restart when travel engaged. Also when steer motor is running but not traveling the lift will not work. The machine functions when moving all work up you let off travel pedal steering works for 5 sec. and lift does not when steering motor stops the lift will work. Have fully charged battery.
  • Posted 15 Oct 2013 08:49
  • Discussion started by donj
  • New Hampshire, United States
I have I replaced the timer card and it works
  • Posted 12 Aug 2014 07:19
  • Reply by donj
does not have an oil sensor ser# 324810513015
  • Posted 16 Oct 2013 07:48
  • Reply by donj
Got a serial number?
this is actually pretty much 'normal' for some 3 wheel linde/bakers.
?does the steering motor 'ramp up' when you turn the steering hand-crank quickly to produce more pressure as you turn? there is a pressure sensor in the steering line before the orbitrol that should make the motor speed up as demand increases. it looks about like an oil pressure sender for an oil pressure gauge.
  • Posted 15 Oct 2013 19:58
  • Reply by edward_t
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
Your Focus
edition #1234 - 12 June 2025
