Unicarriers (& Nissan) CPJ01A15PV:
starts then dies
i have a Nissan forklift model # CPJ01A15PV that will start run for about 5 seconds then die. i have rebuilt the vaporizer and lock off with new diaphragms. it seems like the truck is not getting enough fuel. i can run the truck no problem on starting fluid but when i switch back to propane my problems come back any advice would be appreciated thanks.
  • Posted 26 May 2016 03:06
  • Discussion started by jsanchez89
  • Illinois, United States
You have a fuel issue. You confirmed this by running longer than 5 seconds on alternative fuel.
You may have low vacuum to the lock off. Maybe it's low because of your dashpot leaking? I can't recall if they share the same supply. Regardless apply vacuum to the lock off manually and I bet it will run.
  • Posted 4 Jun 2016 04:36
  • Reply by stam
UPDATE i have narrowed it down to being in the distributor i found that the vacuum advance mechanism was not working (blown diaphragm). i have replaced the vacuum advance but i still cant get it to stay running. if i unbolt it from the distributor i can keep the forklift running but as soon as i bolt it down it cuts out. i have tried to advance the distributor but it doesn't seem to help at all. any idea on what else to try? please let me know
  • Posted 4 Jun 2016 02:39
  • Reply by jsanchez89
TCM FD115-3
Taylor TE650S
Terberg YT220
Tusk 350CGH20
edition #1234 - 12 June 2025
