starts then dies
i have a Nissan forklift model # CPJ01A15PV that will start run for about 5 seconds then die. i have rebuilt the vaporizer and lock off with new diaphragms. it seems like the truck is not getting enough fuel. i can run the truck no problem on starting fluid but when i switch back to propane my problems come back any advice would be appreciated thanks.
  • Posted 26 May 2016 03:06
  • By jsanchez89
  • joined 26 May'16 - 29 messages
  • Illinois, United States
You have a fuel issue. You confirmed this by running longer than 5 seconds on alternative fuel.
You may have low vacuum to the lock off. Maybe it's low because of your dashpot leaking? I can't recall if they share the same supply. Regardless apply vacuum to the lock off manually and I bet it will run.
  • Posted 4 Jun 2016 04:36
  • By stam
UPDATE i have narrowed it down to being in the distributor i found that the vacuum advance mechanism was not working (blown diaphragm). i have replaced the vacuum advance but i still cant get it to stay running. if i unbolt it from the distributor i can keep the forklift running but as soon as i bolt it down it cuts out. i have tried to advance the distributor but it doesn't seem to help at all. any idea on what else to try? please let me know
  • Posted 4 Jun 2016 02:39
  • By jsanchez89
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
September confidence index jumps Fort Collins, CO, United States
Cyngn launches automation subscription model Mountain View, CA, United States
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
