Starts then dies
I have a hyster 110xm with the gm 4.3 lp fueled. It was brought to me due to a bad starter. I have replaced the starter and now what it does is it will start and run for a couple of seconds then shuts itself down starts right back up and does the same thing over and over acts as if there is some safety killing the fuel but I can't figure out what it could be any help or advise would be greatly appreciated
  • Posted 11 Aug 2022 21:56
  • By Kyle_Zemeskas
  • joined 11 Aug'22 - 1 message
  • Kentucky, United States
Kyle zemeskas
although it might be a fuel related issue...
first i would check the oil pressure sensor, they are notoriously prone to fail and when the engine loses oil pressure it will kill the ignition signal and shut down.
A tell tell sign is if you see any leakage around it, that usually means the switch diaphragm inside it is not holding under pressure.
  • Posted 11 Aug 2022 22:42
