Cat Lift Trucks (& Caterpillar) GP18N:
Starts but won’t Rev up
Hi I have the following errors:
E21 Throttle sensor fault
E24 Accelerator sensor fault
E31 Throttle control fault
E36 Fuel sensor fault
Have changed the accelerator pedal, carb c/w all sensors and motor, ECM and checked wiring continuity between sensors and ECM. Does anyone know what might be causing all these accelerator related fault codes?
Thanks
  • Posted 10 Mar 2021 02:27
  • Discussion started by Gary
  • Dorset, United Kingdom
Hi!¨If those errors are active same time, must be some harness problem. Check ground cable too. (battery-frame.)
  • Posted 13 Mar 2021 06:55
  • Reply by Justus
  • Finland
edition #1228 - 1 May 2025
Toyota 8FD35U
Flesherton, Ontario, Canada
Nagano NUL120-6
