Starts but turn off after 30sec
H90XMS
K005V03718Z
LIFT WILL START THEN CUTS OFF. THE GAUGE SAYS THE COOLANT TEMP IS EXTREMELY HOT WHEN THE ENGINE IS COLD. THE CLOGGED FUEL FILTER LIGHT COMES ON AND THE OIL PRESSURE LIGHT COMES ON. IM LEANING TOWARD A DASH ISSUE BUT NOT %100 SURE. ANY HELP WOULD BE APPRECIATED.
  • Posted 31 Aug 2018 22:27
  • Modified 31 Aug 2018 22:28 by poster
  • By robert1985
  • joined 26 Feb'14 - 17 messages
i would check your connections to the display, make sure they are not corroded.
Check the ground as well.
Make sure you do not have any blown fuses in the fuse box.
the fact that it does start and run for 30secs and then shuts down does tell me that the oil pressure switch may be bad. If the engine looses oil pressure it will shut the engine down after a short bit.
check the continuity at the oil pressure switch and make sure it is functioning properly.
  • Posted 3 Sep 2018 00:10
  • Modified 3 Sep 2018 00:14 by poster
Terberg YT220
Terberg YT222
Terberg YT220
Terberg YT222
