Starts after key release
I have a FGCU70 with the 4.3 Vortec. It is powered with LPG. It is just over a year old.
My question is can anyone tell me why when I crank it it will not start until I release the key?
It turns over great. New battery and good clean connections. Timming is good. It just wont start till you let go of the key.
I posted this in the 7fg20 section before I realized I could add a model. Sorry for double post.
Thanks for any help with this.
  • Posted 19 Aug 2007 09:37
  • By Nash
  • joined 16 Aug'07 - 12 messages
  • Tennessee, United States
www.nashvolcat.com
Yeh as I said I was going to try that and I did and so far it seems to be working.
Thanks
  • Posted 30 Oct 2007 12:38
  • By Nash
As someone else said, run a new ground cable from battery to engine. This is straight from Toyota.
  • Posted 30 Oct 2007 11:09
  • By bobby
  • joined 28 Oct'07 - 5 messages
That is probably a good idea. So far the cleaning on the cables has worked but I did notice one if my Hysters has the same problem.
I am going to try and fix that one Wednesday.
I think I will try the extra cable and see if it helps.Thanks for the help Kris
  • Posted 26 Sep 2007 07:16
  • By Nash
www.nashvolcat.com
Run a second ground cable from the engine to the frame where the battery negative cable attaches.
  • Posted 26 Sep 2007 01:36
  • By kristopher_g
  • joined 20 Feb'07 - 6 messages
Finally after checking every wire on this truck I got it.
I took the ground cable off battery where it connects to frame of truck and even though it appeared clean I cleaned a little more and tightned cables (three 0f them) back to frame and it starts as it should.
Can't believe how simple the fix was.
Just thought I would pass this on in case anyone else runs across this problem.
  • Posted 28 Aug 2007 00:48
  • By Nash
www.nashvolcat.com
Thanks Damo, I will give that a shot at tracking it down. I didn't know if maybe the ignition switch itself was bad. Might know this would happen just after warranty expired.
Anyway I will get on it tomorrow and I will let you know if I have any luck.
Thanks again.
  • Posted 20 Aug 2007 01:12
  • By Nash
www.nashvolcat.com
SOUNDS LIKE WIRING ,,,,,,,,WHEN YOU TURN THE IGNITION TO START U MUST BE LOOSING A LIVE TO YOUR COIL OR GAS SOLINOID......
  • Posted 19 Aug 2007 23:25
  • By DAMO
  • joined 9 Jan'07 - 196 messages
  • DUBLIN, Ireland
Lee Rushton Lee Rushton
Taylor T650L
SMV (Konecranes) 16-1200C
VETTER Industrie GmbH
