Linde (& Baker) H18T-03:
Starting Problem
has anyone come across this fault before ?
Truck will not stat voltage to the lock off valve when wires disconnected, when connected no voltage to lock off valve,
  • Posted 11 Sep 2013 06:07
  • Modified 11 Sep 2013 06:15 by poster
  • Discussion started by richard_m
  • lancashire, United Kingdom
Think I'm stuck on this 1 iv'e got voltage when not connected but none when connected.
  • Posted 11 Sep 2013 19:11
  • Reply by richard_m
If you've put voltage to it and it works then it's not shorted or open.....a regular ohm reading for one is around 70-120 ohms I believe
  • Posted 11 Sep 2013 18:42
  • Reply by kevin_t
Hi Kevin how may ohm should a good 1 read?? I put direct voltage to the solenoid and the valve moves. many thanks
  • Posted 11 Sep 2013 14:45
  • Modified 11 Sep 2013 14:52 by poster
Did you ohm the solenoid Coil on the lock off to see if it was shorted????
  • Posted 11 Sep 2013 08:50
  • Reply by kevin_t
Did you ohm the solenoid on the lock off to see if it was shorted????
  • Posted 11 Sep 2013 08:49
  • Reply by kevin_t
Your Focus
edition #1234 - 12 June 2025
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
UN Forklift FBRP15NQZ2
Toyota 5FD60
Your Focus
