Clark CGC60:
starting fault
trucks starts but poor idle.when try to rev truck it dies.
found gassing fault now cleared but still have poor idle when reving up truck it back fires through air filter box and exhaust.
change spark plugs and check distributor time seem right.
still the same.no manuals for truck has anyone got a manual for this truck serial number 010606767fb.
  • Posted 5 Nov 2014 11:03
  • Discussion started by greasespoon
  • somerset, United Kingdom
yep yep...
when that vaporizer/converter starts turning that purty white snowy color and looks like frost that's a bad thing ;o)
bad flow or just low coolant will certainly cause this.
  • Posted 6 Nov 2014 03:09
  • Reply by swoop223
Just ran around the block chasing similar symptoms on a Nissan- check the ignition spark- should be bright blue & be able to jump at least 1/2" w/out changing engine performance- check this at each plug- not off the coil. Never had a dist cap 'eat' spark before but this one was a challenge to find. 1 terminal in the cap almost totally dissipated all spark which didn't show any symptoms except when engine cold or under load. Woulda' bet the house there was a fuel issue.
  • Posted 6 Nov 2014 01:24
  • Reply by bbforks
Gassing fault unit was freezing up water flow problem
  • Posted 6 Nov 2014 00:24
  • Reply by greasespoon
When you say "found gassing fault,now cleared"... can you describe what it was and what you did to resolve it? Sounds like a fuel issue to me did you check and adjust the air fuel mixer(carb) sounds like might be starving for fuel.....
  • Posted 5 Nov 2014 14:44
  • Reply by kevin_t
Aichi RX07B
Terberg YT182
MAXAM Tire, Inc.
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
