stacker spe 160
,hi
I'm facing problems in spe BT stacker 160.
932 162 serial no. The unit issued a code c 29?
then I saw the manual and the command of the manual are instructed to setting parameters (servise interval).
how to setting it?
I really hope its help
thank you mr
  • Posted 7 Feb 2012 14:33
  • By kieza_k
  • joined 1 Dec'11 - 7 messages
  • jakarta timur, Indonesia
Deal To your advice Mr.Forkingabout
  • Posted 10 Feb 2012 14:28
  • By stillengineer03
  • joined 4 Nov'10 - 47 messages
  • Singapore, Singapore
George Peter
georgepeter03 at gmail dot com
Hi
You need a BT can key connected to the truck to be able to turn the C29 service warning off ( parameter number 25 )
Truck OFF
Connect BT can key
Press & hold a horn button
Turn truck ON
Look at display & when P is show release the horn button
Use the throttle butteryfly to scroll the display till it shows number 25.
Press horn button, display now starts flashing.
Use throttle butterfly to change the value in the display to 0
Now press the horn button again, display stops flashing.
Turn truck OFF & remove BT can key.
Job done.
  • Posted 8 Feb 2012 00:59
  • By Forkingabout
  • england, United Kingdom
Muncie, IN, United States
Lift Technologies Inc.
