soft BT
Hello colleague!
I have great problems with RRE160 at replacement CID. It is very necessary TruckCom TE 2.3 or above (I have interfaces USB and COM). In the Manual it is written that it is necessary to copy a configuration from the another truck. Help me please!
(mail: wert2035@ramblerdotru)
  • Posted 1 Mar 2012 12:55
  • By Last
  • joined 25 Jan'12 - 17 messages
  • Siberian, Russian Federation
Hi
1st thing first, what software package is currently in the truck?
Package number will be 260038 then ****, what is the **** number on your truck?
  • Posted 2 Mar 2012 08:12
  • By Forkingabout
  • england, United Kingdom
Hello Forkingabout
The main problem - I don't have BT Truck Com TE software new versions.
Before consolidation ВТ and Toyota in my region in 2010 my company officially represented interests ВТ. I was technician ВТ seven years... Interfaces remained. Clients too remained and want service.
  • Posted 1 Mar 2012 23:15
  • By Last
If you have replaced the CID unit you may also find there is a software mismatch with the rest of the nodes.
1st - do you have BT Truck Com software?
2nd - what software package is currently installed in the truck?
Connect the original CID to the truck, truck OFF, Press I button & look at CID display, it should have Truck Serial number & pkg: then 260038 - ****
Its the **** part of this number thats VERY VERY IMPORTANT to know!
You will actually need to copy the configuration from the MCU to the new CID, in Truck Com, drop down menu box on right, scroll down to COPY CONFIGURATION.
Open that & 2 options will then show up, select the Copy configuration from MCU to CID option.
Click that, then click YES on the warning box, wait till its finished copying then fingers crossed job done.
Truck Com 2.3 is pretty old, I know version 2.6 or later works on an RRE.
Where did you manage to get the interfaces from?
  • Posted 1 Mar 2012 19:16
  • By Forkingabout
Muncie, IN, United States
Terberg RT403
UN Forklift FGL25T
Terberg RT403
UN Forklift FGL25T
