slow travel. hyd ok
Truck just creeps. Have checked programming and changed motor,drive,controller , handle angle switches checked all wiring. Am at a loss as it shows no codes
  • Posted 22 Dec 2012 03:45
  • By stevepops
  • joined 22 Dec'12 - 10 messages
  • Oklahoma, United States
Glad it was that simple. No problem. You may want to put an email in your profile so people can send you info.
Happy Holiday's
  • Posted 23 Dec 2012 05:56
  • By rogeriwt
You were right. Two wires were crossed in the previous repair
Thanx again
  • Posted 23 Dec 2012 05:35
  • By stevepops
no problem. They can a huge pia. I usually end up replacing the harness, it is the easiest way to go. The have some harness issues.
  • Posted 23 Dec 2012 03:23
  • By rogeriwt
Thanx I belive they are wrong will check and let you know.
  • Posted 23 Dec 2012 02:48
  • Modified 23 Dec 2012 05:34 by poster
  • By stevepops
handle facing you. left side 24 top 51 middle. The right should be 20 top and 50 middle. There is an updated harness and I would recommend putting it in because the numbers are different on the info I have. If you buy the harness request getting the bulletin for installation. I think the wires are tie wrapped together and run in a pair so you may want to try the pairs together with the 50's on the middle spade. Good Luck.
  • Posted 23 Dec 2012 02:09
  • By rogeriwt
What numbers go where ? I think I have 20.1. 50.1 & 51.1. 24.1
  • Posted 22 Dec 2012 21:21
  • By stevepops
You may also want to make sure the wires are correctly on the switches. If the are backwards it can do some weird things.
  • Posted 22 Dec 2012 10:35
  • By rogeriwt
Does the handle actuate the switches properly. I did have one that everything checked out but the handle never hit the switch.
  • Posted 22 Dec 2012 10:33
  • By rogeriwt
Yes sir. There was one broken and one pinched in a previous repair. This fleet is new to me so I don't know much history the previous tech was a "put a bandaid on it " kind of guy. I have 32 p/j s and 15 forklifts. So I got some work to do to get them back right.This one is just giving me fits.
  • Posted 22 Dec 2012 08:09
  • Modified 22 Dec 2012 08:10 by poster
  • By stevepops
Did you pull the handle assembly off the truck and check where the wires come through?
  • Posted 22 Dec 2012 07:26
  • By rogeriwt
No binding at all. Does not want to build any speed at all.seems like the motor is bad but does the same thing with known good motor and drive.
  • Posted 22 Dec 2012 05:21
  • By stevepops
any mechanical binding in the gears? Does it do it with the wheels off the floor? brakes dragging or hanging up bad?
  • Posted 22 Dec 2012 03:54
  • By kevin_t
edition #1281 - 14 May 2026
UN Forklift FBT20NQZ1
Still GX10
Still GX10 2000
Poland
EUR950
Nils Altrogge Nils Altrogge
