Slow lifting with operator onboard
I have a machine that shows an 02 code for just a second and the clears up ,but it's slow raising up with operator onboard and only runs in slow mode. Any suggestions?
  • Posted 24 Jun 2021 03:21
  • By bruce864
  • joined 1 Mar'16 - 40 messages
okay, i'm gonna try it.
  • Posted 22 Apr 2022 04:52
  • Modified 24 Apr 2022 21:57 by administrator
  • By jose_sally
  • joined 22 Apr'22 - 1 message
  • Brunei Darussalam
Park the scissor lift in a well ventilated area near an electrical outlet.
Press the emergency shut-off switch to prevent another operator from unknowingly driving away while the lift is plugged in....
Locate the battery charger on the base of the lift on the right side.
  • Posted 26 Jun 2021 15:16
  • By saltbayfour
  • joined 24 Jun'21 - 2 messages
https://forpc.onl/ https://jfi.cam/jiofilocalhtml/
How do you charge a GS 1930 scissor lift?
  • Posted 24 Jun 2021 20:38
  • By saltbayfour
hello bruce,
the 02 code is a communication error between the platform and the ecm.
usually caused by a bad control cable or a problem in the platform control.
I would open up that platform control box and check the joystick assy and hardware and wiring real good in there. It might have some parts on the joystick that may have vibrated loose which might be causing the error and the slow operation.
  • Posted 24 Jun 2021 14:03
Aichi SR10C1SM
Terberg RT223
Combilift Ltd
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
Combilift Ltd
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
