Slow in engaging Forward or Reverse
Hi everyone,
I have a Komatsu FD 150 -7 which is haveing some issue on the Foward & Reverse Transmission.
It takes quite a while (about 30 to 40 secs) to move after engaging the forward or reverse lever.
Can any kind soul enlighten me what might be the problem ?
Thanks in advance.
  • Posted 12 Mar 2013 15:13
  • By stanley_a
  • joined 11 Jan'13 - 4 messages
  • Singapore
we have a komatsu fd 150 1996 model...
its runs very slow in forward and reverse...
we have cleaning the oil line and change oil the transmission...
but it still slow..
its newly overhauled engine (izusu 6bg1)
  • Posted 31 Jul 2014 10:28
  • By inz_007
  • joined 31 Jul'14 - 1 message
  • cebu, Philippines
after checking the 'spools' on the control valve you may want to try servicing the transmission.
change the fluid and clean out the sump screen at the base of the housing where the return supply line hooks to.
if it has not been serviced in a while it could be clogged up not letting enough fluid through which would cause the delay in the clutch packs engaging.
this is a common occurance in all lifts that don't get the transmission serviced properly.
  • Posted 29 Jun 2014 23:24
  • Modified 29 Jun 2014 23:25 by poster
Maybe just check the control valve on top of the transmission to see if spills are sticking inside
  • Posted 29 Jun 2014 15:10
  • By clinton_b
  • joined 29 Jun'14 - 18 messages
  • Queensland, Australia
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
