SHUTTS OFF
WE HAVE A YALE GLP050ZG , A875B30906B , 3.0 GM , LP , STARTS FINE , CUTTS OFF AFTER RUNNINING FOR A MINUTE , RUNS FINE , HAVE REPLAECED , DIST MODULE , THIS FORKLIFT HAS A CRANK SENSOR , ALSO REPLACE CRANK SENSOR , NO CODES , JUST CHECK ENGINE LIGHT ON , STARTS EVERY TIME , JUST WONT STAY RUNNING , ANY HELP TRULY APPREICIATED , THANKS SERGIO GARCIA
  • Posted 26 Jan 2021 04:39
  • By sergio_g
  • joined 25 Sep'18 - 8 messages
411lift
Since the engine runs fine, either the LP is running out or electrical heats up quickly and shuts down. You probably have this fixed, but first thing to do on a problem like this is to change out tank. Then install spark test and see if you are loosing spark when engine shuts down. Make sure you are not loosing voltage at the shut off solenoid.
  • Posted 19 Mar 2021 23:58
  • By Fishmech
  • Virginia, United States
REPOWERTEK Inc
Maxlion R2B25LI
Big Joe PDR30-154
USD7,500
REPOWERTEK Inc
