showing error code f0-2 on 7fbcu25
can someone tell me what this code is? thanks so much.
  • Posted 4 Jun 2014 02:54
  • By paul10
  • joined 18 May'12 - 15 messages
So if everything works as needed then we need to check voltage. Connect battery with key on. At connector CN 103 on the CPU Board from CN 103-12 to CN 103-13. Readings of 0 V (OK) possible Harness or CPU Board. Reading of 5 V (NG) PBEHPS (Printed Board EHPS)
  • Posted 25 Jun 2014 10:39
  • By Bulldog965
  • joined 15 Oct'09 - 63 messages
  • Indiana, United States
Yeah the truck runs fine
  • Posted 25 Jun 2014 08:53
  • By paul10
The EHPS (Electronic power steering circuit) sees power going through the motor even though the EHPS is not on. Two questions: Does the power steering motor run with truck plugged in? Does it run when turning the steering wheel?
  • Posted 24 Jun 2014 11:59
  • By Bulldog965
Richard
