I need to replace an "actual value pot" the steer pot connected to the steer wheel on a Lanser Boss WA10 that has been damaged. I should be able to set it by setting the steering wheel "target value pot" to the middle position, the steer wheel straight and then set the actual value pot voltage to half the pot supply voltage. But if anyone has the setup procedure I would appreciate a copy.
Regards Shane
