serial numbers ????
gentlemen of the world.i have a jungheinrich ERE20 stand-on pallet truck with rating plate missing. des anybody know if it is stamped on the frame under the paint or hidden elsewhere. regards
kev
  • Posted 5 Jan 2007 05:24
  • By kevin_k
fix it right first time
hi kevin i have some literature inc fault codes on ere 20 from year 1995 1999 if u still require it also have spares inc 1510 micropulse
  • Posted 13 Jun 2007 05:19
  • By milo
  • joined 13 Jun'07 - 19 messages
  • dublin, Ireland
hi philip. do you know where i could get my hands on some literature for jungheinrich pallet trucks. i,ve taken 5 on and they have been butchered. cheers
  • Posted 26 Feb 2007 06:40
  • By kevin_k
thanks philip. do you know if this is the common place to find serial numbers on jungheinrich pallet trucks. as i have a few different models to look after i,e fixed platform , hinged platform and standard walk behinds all with rating plates missing.regards kevin
  • Posted 18 Feb 2007 02:28
  • By kevin_k
The truck serial number should be stamped on the top frme (right) between the battery housing and motor panel. Once you have that you can phone Jungheinrich and have a rating plate supplied. Having said that you have a two ton truck capacity, ERE20.
  • Posted 18 Feb 2007 00:33
  • By philip_t
  • joined 5 Jan'05 - 3 messages
  • Cleveland, United Kingdom
