Cat Lift Trucks (& Caterpillar) P5000:
serial number AT35 00047
Top of the dash has all your fault lamps. Top middle is a exclamation mark that came on and stays on. Hour meter won't display because there is something trying to display but never really gives you an idea what it is. Almost looks like part of a p. Unit runs good but I can get the lamp to flash on and off if I run hydraulic lever into relief and lowers the RPM's. If I lower the RPM's then my hour meter displays a fault code "24". Any idea why lamp is on? Need help!
  • Posted 14 Dec 2017 04:01
  • Discussion started by easymo
  • Michigan, United States
Or code F-24
Attach-1 lever error
  • Posted 14 Dec 2017 05:05
  • Reply by kevin_t
Could be cide E-24..
Accelerator sensor error signal
  • Posted 14 Dec 2017 05:03
  • Reply by kevin_t
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Load Lifter 1056H
Flesherton, Ontario, Canada
Ice 28INCH-AUTO-SCRUBBER
USD8,350
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
