Cat Lift Trucks (& Caterpillar) EP16KT:
s/n ETV4A00374
We replaced the main board with the 6 connectors and now we have the error code 65. Can you help?
  • Posted 2 Aug 2012 19:14
  • Discussion started by mapapada
  • attica, Greece
good luck
code 65 indicates a faulty dsw setting
replacing the logic card i presume?
the dsw settings have to do with truck type and these settings will have to be programmed into the new logic card to make this code go away and let the truck run.
dsw 2, 3 and 8 settings are not correctly set for truck type so logic shuts truck down and error's out code 65
hopefully you have the old card still?
remove the cover and make sure the dsw switchs are set the same on the new card
DSW2:on DSW3:on = 2.0 ton class
DSW2:off DSW3:on = 1.8 ton class
DSW2:on DSW3:off = 1.6 ton class
DSW2:off DSW3:off = error (code 65)
DSW8:on = FC control
DSW8:off = MC control
if you dont still have the old card then these settings above may be of some help
good luck
  • Posted 2 Aug 2012 21:42
  • Reply by Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Toyota 8FD45
edition #1228 - 1 May 2025
