runs, won't move
I have a 2014 Toyota series 8 lift. It starts great. won't move when put in gear. seat light stays on. wiring good going to seat pressure switch. Also unable to get any codes or readings with handheld reader.
  • Posted 16 Aug 2016 22:19
  • By Bart
  • joined 16 Aug'16 - 7 messages
You need check the puns on the conectors.... sometimes alll looks ok, but inner there not contact. ( sorry for my english).....
  • Posted 2 Sep 2016 15:46
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
what else controls dash light fork symbol besides seat switch?
  • Posted 1 Sep 2016 22:50
  • By Bart
yeah, I tried all that. jumped the switch, tested wiring, traced all the way to ecm. switched ecm with working unit. still nothing. light on dash with wrench symbol. can't read code with reader. not sure if we can get flash codes on these.
  • Posted 19 Aug 2016 03:23
  • By Bart
Bart,
have you tried pulling the seat to confirm no issues on wiring or switch. the light has to be out so somewhere there is a bad connection or a bad switch. I have had several where the switch was bad. I have also seen junk get under the seat and ruin wires. you can pull the plug and temporarily jump it to confirm, I think the plug is under the hood and maybe another under the seat
  • Posted 19 Aug 2016 01:23
  • By ray_j
  • joined 22 Aug'14 - 13 messages
  • Missouri, United States
UN Forklift FB25N1LZ1
Factory Cat MICROMAG20D
