Runs rough
I just started working on this truck. It acts like it is missing at low rpms. Rebuilt the regulator which helped for one start up. Now it is back to the original problem. Cleaned the cap and rotor up but that didnt help. I am plannning on installing a tuneup kit but just wondering if it could be any other problems. It seems more like a fuel problem.
  • Posted 9 Jul 2013 22:49
  • By Lift_Boyz
  • joined 24 May'13 - 22 messages
it turned out to be a tune up problem/ one of the plugs was loose.
  • Posted 24 Jul 2013 22:07
  • By Lift_Boyz
On some of the v6 engines it helps if you add an extra ground wire to the engine. Has been an issue with them for a while, if they crank for a long time before starting. I have run into plenty of issues with coils on them too.
  • Posted 12 Jul 2013 11:54
  • Modified 12 Jul 2013 11:55 by poster
  • By rogeriwt
Check the fuel line between the regulator & the mixer assy- even the slightest leak will cause problems.
  • Posted 10 Jul 2013 03:18
  • By bbforks
Also, it cranks awhile before starting.
  • Posted 9 Jul 2013 23:43
  • By Lift_Boyz
Toyota 02-2TD20
Unicarriers FD80-2
