Mitsubishi FGC30:
Running Hot
Forklift was overheating found a broken thermostat, replace it and installed a new water pump also. Continues to run hot but not overheat.
Took compression reading (cold)
Piston 1 - 130
Piston 2 - 120
Piston 3 - 140
Piston 4 - 155
Could anybody tell me if these numbers are good?
  • Posted 15 Mar 2008 02:04
  • Discussion started by albert_h
Those numbers are not to bad, Can I assume these are dry readings, meaning you did not squirt some oil in spark plug holes before checking? A cylinder leakdown test is more accurate than the old compression test Also, are you using gauge reading for your determination of "running hot"? I have seen sending units get damaged from "overheats" and give "false" gauge readings after problem is fixed. If you don't have a hand held temp tester, try new or "known"good sending unit. Radiator in good shape? ---Take radiator cap off and idle truck and look for air bubbles--might have to fill rad up to top to see good.
  • Posted 22 Mar 2008 11:46
  • Modified 22 Mar 2008 12:03 by poster
  • Reply by roadrat
Hangcha FLDCXT160
Toyota 02-8FD25
