Running hot
I have a 8series that is running hot. The radiator split on the plastic side. I put a radiator water pump thermostat. Ran hot again, put a head and gasket both temp sensor. New thermostat again, still runs hot. Have bled the system what am I missing guys? I have literally redone the entire coolant system what else will cause my overheating
  • Posted 3 Jul 2021 12:05
  • By CodeyB
  • joined 3 Jul'21 - 1 message
  • Mississippi, United States
How long does it take to run hot. Upon starting and then hot or after 1/2 hr??? If over a hour , check inch pedal cable adjustment. Slipping the transmission will cause overheating by just losing a few pounds psi on having it adjusted correct or operator is misusing the pedal and riding the clutch so to speak.
  • Posted 5 Aug 2021 21:47
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
JCB 533-105
Ncn 85TH
Ncn 85TH 2014
JCB 533-105
Ncn 85TH
Ncn 85TH 2014
Briefs United States
