running but no power
The above mentioned fork lift has a problem with the power when i first look at it the mixer was leaking so I took it of and put a new kit in it its a impco by the way turn on the gas leak stoped started the forklift still had no power its like when you press the gas pedal it rates up and then it dies change the gas tank service the engine still no change so i change the carburator still no change Iam wondering if there is a shut of valve some where that is powered by current. thanks help.
  • Posted 25 Jan 2010 13:25
  • By billy2057
  • joined 20 Nov'09 - 7 messages
  • bahamas, Bahamas
thanks I will check the valve on monday thanks again
I check the line and found the filter change it and bam the problem is fixed thanks a lot
  • Posted 25 Jan 2010 13:47
  • Modified 26 Jan 2010 13:58 by poster
  • By billy2057
  • bahamas, Bahamas
There is a electric shut off valve and it has a filter in it that gets plugged causing that problem. Follow the hose from the tank and it should go to the valve.
  • Posted 25 Jan 2010 13:39
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Mitsubishi Logisnext FD25T5M
Hitachi HX64B2
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
