Bt Industries RRE250:
RRE250/6300352 2014
Hi Everyone.
in my truck steering system not working Error code 5:184 and 5:385
i have replace the pluse transducer in the steering wheel.
i have replace the Reference sensor also.
Problem is still there with same error..
any one can help me on this issue
  • Posted 19 Jul 2019 15:36
  • Discussion started by muzffar_h
  • United Arab Emirates
Does your RRE have one or two steering reference sensors fitted?
Was the sensor you replaced under the silver metal bar that supports the pedal / floor unit?
If the truck has Safety PLUS fitted there is a second steering reference sensor fitted directly in front of you when you open the motor compartment.
What does go on these is the gearbox radial bearing fails & if its left to long the gearbox can move during travel over a bump & damage the steer sensor.
Jack & support the truck safely so the drive wheel is clear of the floor, grab a large bar & check for radial bearing play by attempting to lift the drive wheel straight up levering it with the bar, if the radial bearing is faulty you will see / feel the play this way.
Its very rare to get a real steering fault on a RRE.
  • Posted 21 Jul 2019 01:14
  • Modified 21 Jul 2019 01:14 by poster
  • Reply by Forkingabout
  • england, United Kingdom
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
Dubuque, IA, United States
Louisville, KY, United States
