reverse OK- NO forward gears
Checked inching valve- it is OK.
Checked shift lever- OK there-
Changed fluid-
runs fine in reverse and mast runs fine.
  • Posted 21 Jun 2015 08:21
  • By 303wrench
  • joined 21 Jun'15 - 2 messages
  • Colorado, United States
What did you find on this forklift. Have same issue with an 7FGU25.
Thanks,
Mike
  • Posted 4 Aug 2016 00:58
  • By Mikeg
  • joined 4 Aug'16 - 1 message
Seems wiring is ok i get feed correct from the gear lever to the wiring that goes into the transmission connector.
and it ever so slightly seems pulls itself forward on a flat concrete floor when you engage forward.
Almost as if its only getting 1/100th the power it should.
  • Posted 25 Jun 2015 07:24
  • By 303wrench
you might want to check for wire breakage. in the harness. lots of issues with Toyota harnesses.
  • Posted 24 Jun 2015 20:28
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
