Return home mode after 3 hrs
As stated the unit will run fine for up to 3 hrs then dive into limp mode. Cycle the key and it will run anywhere from 45 min to 2 hrs then dive again. It does NOT display an error code. Check engine light will appear. Fluids are good. Any help is appreciated. This job was given to me after a different tech replaced the cap rotor plugs and wires then called it a day. Vaporizer had a sight build up going into the dry gas hose, nothing obscene.
  • Posted 16 Apr 2020 06:08
  • By Nberente
  • joined 16 Apr'20 - 1 message
-Nick
If check engine light is on then a mil code should be present. Need engine cable and laptop to provide diagnostic specs. Should be able to watch engine components operate on program to see what is faulting out when mil lamp is on.
  • Posted 16 Apr 2020 20:22
  • By ron_k
  • joined 2 Apr'15 - 127 messages
  • North Dakota, United States
4kliftman
Maxlion FDR45
Crown CG33P5
Lift Tek Elecar
Michel Denis Michel Denis
