Report this forum post
A little word of warning about this model that are "long in the tooth". I've got 2 customers with these and both of them have had the stub shaft that is welded in to the frame and supports the mast, break. It is a shaft that is about 1 3/4" in diameter and 4" long that the mast sits on with the U shaped clamp around the back. It is welded in to a hole in the frame. Crown makes a replacement pin for the newer ones but not for older ones.
To fix it you must remove the mast, pull the drive unit gearbox out of the way, grind and punch out the old piece of pin, and weld in the new one. I had to make a pin for the older unit that was not available.
Anyway, both are fixed and the trucks have held up very good other than that. One has been their dock truck for 15 years, going in and out of trucks all day.
  • Posted 4 May 2014 23:04
Indicates mandatory field
Toyota launches three new stackers Columbus, IN, United States
Orlando area, United States
Tacoma, WA, United States
Highland, IL, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Terberg YT220
Mitsubishi FGE35AT
