Report this forum post
What type of horn is fitted to your tow tractor?
BT use SKF encoder bearings on the older Reflex reach trucks & they had to fit a supressor on the horn circuit as electrical spikes could blow 1 of the motor / height counter sensor bearings.
2 pin horns the suppressor was piggy backed, later trucks used a 3 pin horn with built in supressor.
We where told if a encoder bearing was ever replaced then the horn / supressor must be replaced to & recorded on job sheet else they wouldnt warranty the part if it failed again.
  • Posted 23 Mar 2012 01:04
  • By Forkingabout
  • england, United Kingdom
Indicates mandatory field
Muncie, IN, United States
