Report this forum post
Josh,
When changing the battery, was the setup changed from lead acid battery to lithium battery? If not, this could be the cause. Most of the time there are multiple adjustments that required when installing lithium. Good Luck.
  • Posted 10 Sep 2024 22:58
  • By Fishmech
  • Virginia, United States
Indicates mandatory field
