Report this forum post
Hi Mr Pitt. Great advice from Skyreach and Scott re the wires to from the distributor and to not only test for continuity but also ohm as there is a diode in one of these that may have failed. You might need to replace one of these.
If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
You can also request access to our knowledgebase where you will find more information available. Hope you get sorted.
Combilift has a technical team in Australia and they will be more than happy to help you.
  • Posted 2 Feb 2024 21:16
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Indicates mandatory field
TCM FD80Z7
TCM FD80Z7 1990
Enforcer FD50T-MMA
