Report this forum post
When calibrating the pot make sure to push the pot as far as possible. You can check the voltage in the analyzer menu A2.2.7 the voltage should be between 2v and 11v when using the pot. If it is outside that range replacing the pot should solve the issue.
  • Posted 22 Dec 2023 00:17
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 223 messages
  • Wisconsin, United States
Indicates mandatory field
