Report this forum post
Stability triangle applies to 3-point trucks, which is almost all of the most common lift trucks, such as 3-wheel and 4-wheel Counterbalance Trucks, even Reach Trucks and Order Pickers.
The Crown TSP is not a 3-point truck. It is a 4-point suspension system, therefore no stability triangle. This provides excellent stability, and greater capacity at higher elavations, unlike a Raymond Swing Reach which is a 3-point truck. The Crown requires a very level floor.
It is true that minimum and maximum battery weight is specified, however in most cases, a battery, or batteries perhaps for a TSP, which exceeds the max weight permitted won't fit in the box anyway. Max battery weight pretty much fills the battery box completely.
  • Posted 21 Jul 2005 23:45
  • By brian_c
  • joined 10 Dec'04 - 5 messages
Indicates mandatory field
Toyota 02-8FD30
Manitou M50-4
